Old 04-11-2017, 09:03 PM   #3
paulofto
2003 S, Arctic Silver, M6
paulofto's Avatar
This is likely the most common issue with the 6 speed trans, likely more common than the second gear pop out or second gear grinding. Unless you are losing so much fluid that it pools in your drive way it is not a big problem. The bushing is fixable but cost is high and takes removing the trans.
Mine has this issue but is more like a 'weep' than a 'leak'. It has done its since I bought it 4 years ago and has not gotten any worse.
