Servicing A/c is quite complicated and requires special equipment.It is easy to make the problem worse. So unless you want to climb a steep learning curve and buy the equipment it is usually better to use a specialist. Meanwhile you could just get a recharge kit and try that
https://www.youtube.com/watch?v=Wn0C9jPOAAQ
