Old 03-28-2017, 02:50 AM   #133
itskenallen
itskenallen's Avatar
Originally Posted by oldskool73 View Post
I'd not connect that wire to anything yet then, take the headlights completely out of the equation, just connect the controller to the battery and the red & black wires to the DRL and see if they light fully. If they still don't light fully you have a faulty drl and/or controller.
Also, looks to me like in the image you attached they have mislabeled the wires. Looks like the one labeled 'DRL negative' is a white wire in a black sheath, from all the controllers I've seen it's normally a white wire that should be connected to the headlights for the dimming function. And the one marked 'Headlight / dashboard light' looks like the black negative wire that should be going to the DRL. If you've followed the labelling in that image, it's possible you have those 2 swapped around, which would blow the fuse and/or cause them not to light.
Yiu could possibly be right. I thought that wiring diagram was very strange too. Maybe that is the issue. Maybe I've blown the controller now because of that.
Here's the link to the controller I got so u can see for yourself it's wiring.
Look at this on eBay http://www.ebay.co.uk/itm/281928002375
itskenallen is offline   Reply With Quote
