Old 03-28-2017, 12:27 AM   #131
oldskool73
oldskool73's Avatar
Originally Posted by itskenallen View Post
Problem is they're not lighting fully at all, even with the ignition on and the headlights off.
I'd not connect that wire to anything yet then, take the headlights completely out of the equation, just connect the controller to the battery and the red & black wires to the DRL and see if they light fully. If they still don't light fully you have a faulty drl and/or controller.
Also, looks to me like in the image you attached they have mislabeled the wires. Looks like the one labeled 'DRL negative' is a white wire in a black sheath, from all the controllers I've seen it's normally a white wire that should be connected to the headlights for the dimming function. And the one marked 'Headlight / dashboard light' looks like the black negative wire that should be going to the DRL. If you've followed the labelling in that image, it's possible you have those 2 swapped around, which would blow the fuse and/or cause them not to light.
oldskool73 is offline   Reply With Quote
