Old 03-25-2017, 02:40 PM   #12
jsceash
jsceash's Avatar
You can pull the cover off the 2003 and newer but it is very cramped. The front half of the cams 4,5,6 and rear of 1,2,3 are secured with 2 bearing caps. Turn he motor to TDC. remove the green end cap off the rear of the cams 4,5,6 and front of 1,2,3, part # 99610421554 (2 a side or 4). You have to have the cam setting tool a flat plate that fits in the end of the cam shafts at TDC and bolts to the head. (also most the tension is off the cam in this position as well). Once it's installed you can remove the valve cover, which has three seals on the end of the spark plug socket part # 99610420300 (3 a side or 6).
