If you can get your car to the track without driving it there. The Hankook Ventus Z214 is an inexpensive choice in a slick tire 245-40-17 set of 4 are under $800 I turned some really good track times last year on these tires. I run the 18" size. The catch is I'm also running allot of (-) camber -2.5 to -3 with about 4" front and 4.5" rear ground clearance.
If you can't and have to drive to the track. Try the Nitto NT01 or Toyo R888. are as close to a slick as you can get and drive it on the street to the track.
