Old 03-24-2017, 02:29 PM   #1
SteelStroke
2003 S Spark Plug O-Rings
Not sure if the title is spot on but here is the issue:
Oil leak/Smell has gotten worse over the past month.
Going to torque down the valve cover bolts this weekend to see if that is it. Also De-grease the engine shield.
I have read that in the 03 S that it does not have the plastic spark plug tubes as earlier models and that the O ring/spark plug tube seals are now integrated into the valve cover or cylinder heads. True or false?
What parts are needed to fix if so? Searched here and Pelican but could not find anything that was conclusive.
TIA
SteelStroke is offline   Reply With Quote
