Old 03-22-2017, 09:09 PM   #5
AZ986S
AZ986S's Avatar
Chuckie is a great fun safe track
You don't need 2nd anywhere, 3rd all around and hit 4th on the front and back straights
definitely not 2nd in turn 9, you will have to upshift in turn 10
2:17 is very respectful for a 1 time out in a 986
What tires are you running?
I run 30/30 hot on RE-71's
Thanks.
I'm running Hankook R-S3s. They seem to like 37-38 all around hot.
I'm thinking it will be very HOT there in the summer, so my next outing there will most likely be October or November. I'm sure I could shave some time off with more seat time on that track...
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
