Old 03-18-2017, 01:11 PM   #12
jsceash
jsceash's Avatar
not yet. i have the 997 unit, and tonight i measured it, as well as opened my engine and measured the 986S unit, just to reconfirm the 15 mm height difference. the difference is certainly not 'a couple of inches' as jfp said. there is about 20 mm clearance over the 986S unit; again only potentially the need to trim the vent tube.
Did you ever install that unit? I looked at my 2.7L motor in the garage. I have about 6.5" under the manifold. Was there more clearance in the 2003-04 engines than earlier models. Do the opening line up the same?
