Old 03-17-2017, 07:51 AM   #4
thstone
Do you still have your little triangle tread indicators on the side? If those are worn off then you might be running too low of air pressure and that will wear out the edge of the tire early. (More experienced folks - is this true or is it an old wives' tale?)
This is true as far as I am aware and I still use it. But realize that its only a rough gauge.
A better method is to use actual tire temps taken at several points across the tire width using a pyrometer (a meter with a needle-style probe that touches the tire to take the temp) and then using tire pressure to balance the temps. The downside here is that you have to buy a new device and learn to use it, but it will provide very accurate info. I'l admit that I have not gone to this level. Yet.
