Old 03-15-2017, 10:02 PM   #1
oldskool73
oldskool73's Avatar
thanks PW... although I actually meant how to get the bit with the posts in, in the left of your hand, out from where it's set inside the case? I can raise the clip at the front and twist it, but the tabs are keeping it locked down still. Or do I need to get the bottom bit in the right of your hand unclipped first before it comes out? ... or I could just solder to the posts and forget it
Yeah I've already redone the wiring once, but I used crimp connectors thinking it'd save space but it just looks a bit messy, might cut them off and put the h7's back instead.
oldskool73 is offline   Reply With Quote
