Old 03-13-2017, 09:18 AM   #1
CN58
Water pump longevity ????
Have a 99 Boxster w/ 91K.. Runs perfect.. Read about water pump and stat failure.. So I decided to change them.
Changed the water pump and stat this w/e. The old pump looked perfect, no shaft movement. The composite impeller all intact. How long does a water pump last in these cars ?? I've heard some horror stories about pumps failing and spitting pieces of impeller into the system.
Went with metal impeller pump and a 71C stat. The other question is ?? Will the 71C stat help bring the temp down a few degrees. Ran a 'little" warmer than I liked last summer.. Anybody got experience with the swap to a 71C stat ??
CN58 is offline   Reply With Quote
