Old 03-10-2017, 06:36 AM   #1
thstone
I spent months looking at all of the options and came to this conclusion: If you have the room, a four or two post lift is a much better solution and only a little bit more money. If you're space constrained then a unit like this is a great way to go. I had the room, so I have a four-post lift.
The only other comment I'll make is that people tend to get lazier over time, so the easier it is to set up and use, the more often it will get used.
