The seal goes in to the mm and sits just inside the old wear point. I used the bell end of 3"PVC and it was the perfect install tool. Then set a small depth gauge.
You drill a hole in the old one then put a screw in that hole and remove. Don't push it into the motor.
'08 VW Touareg T-3 wife's car
