			As long as you leave the key out of the ignition (to help you to remember to not crank the car which will set the airbag light if the seat belt receptacle isn't plugged in for both seats) you can swap seats without disconnecting the battery.
As far as the plugs for question #1 - I think the plug is the same but may just have less wires. Maybe Woody knows? He has removed a lot of seats I bet. You could have the seller send you a photo of the plug and compare it with yours?
For #2 - seems like it would be crazy for them to be different - and for the aftermarket rails that are available I have never seen any UJ only versions. Best guess is they are the sane.
