More progress today!
All of the damaged parts removed. The door jamb, firewall, and front tub appear nice and straight. Coolant lines and brake lines were still intact. Caliper and hub appear fine.
Radiators replaced and engine running fine. Inner/outer tie rods replaced. Control arm replaced. Stock strut used as a stand-in until a replacement PSS9 is found.
The fuel filler tube is pretty mangled!
