Old 02-22-2017, 11:42 AM   #15
WorkInProgressK
Originally Posted by Qmulus View Post
The oil cooling is not the big issue on a track car. Oil supply to the bearings is, and no added capacity oil pan, X51 baffles, dual scavenge pumps, etc., or even Accusump will solve it. Those are "peace of mind" fixes for street cars, but don't really solve the basic problem of oil control in the engine. The only true way to keep a tracked M96 or M97 alive is a dry sump system. You might be able to get away with some of the band aids for a while on some tracks, but sooner or later you will lose the bearings.
But those failures could be prevented by replacing the bearings with a refresh. The issue is that unless you need an engine to last a long period of time, refreshing it would be more cost effective.
On the subject of the cooler. Wouldn't having a better cooler cancel the benefits of running thicker oil? Wouldn't running a lighter fluid provide better flow and protection to areas with smaller passages? I know the argument about tracked(daily drivers) cars need thicker oil, but that is considering that oil will rise much higher then stock, lowering its weight to a more suitable thickness.
Also more heat taken from the oil = more heat in the coolant = higher average engine temperate. No idea if that is more suitable then a high but acceptable oil temperature with lower coolant temperatures.
2001 Boxster S (SOLD)
1991 Nissan Silvia "K"(Forgotten somewhere in Canada)
1989 240sx (Track car)
1987 325IS (Soon to be Spec E30 racecar)
2001 GSXR-600 (Almost warm outside!)
WorkInProgressK is offline   Reply With Quote
