Old 07-21-2006, 01:44 PM   #5
MNBoxster
Originally Posted by eslai
Wow, the clutch master cylinder's inside the car? I've never seen that before. Seems like a seal failure there could end up as a pretty big surprise for the driver!
Hi,
Yep, located just behind the top of the Clutch Pedal Shaft on the inside of the firewall.
It shares a Fluid Reservoir with the Brake Master which is located in a more usual spot under the left side Inspection Cover under the Hood, but a Hydraulic Line runs from the Brake Master through the firewall to the Clutch Master and another Hydraulic Line runs from the Clutch Master, through the firewall and back to the Clutch Slave Cylinder.
Be sure to tape a dropcloth on the floor and up the side if ever servicing this Master or it's Carpet replacement time...
Happy Motoring!... Jim'99
