Old 02-21-2017, 08:00 AM   #1
Kurt V
Turns out I've got a couple of problems. First, yes one of the plastic ball joints was broken. However, the rod on the other side appears to have popped off and is bent. Here is a picture of the two rods:
So it looks like I need one plastic ball joint and I either need to try to bend the rod back to the correct shape or get a new/used one. Any suggestions as to where to buy the plastic ball joint and the rod?
Next issue, cable on both sides are frayed. Where is the best place to buy new ones?
Next issue, this hook holds down the top liner just behind the passenger side seat, but I can't find where it hooks. Any help?
Finally, this cover piece was just laying in the well where the top goes down. Was on the right side. How does it fit. Should there also be one for the left side? If so it is missing.
Thanks for all of your help!
2003 Boxster S
1991 BMW 318is
'93 Ducati 900SS
'76 BMW R75/6
'73 Honda Scrambler
Kurt V is offline   Reply With Quote
