Originally Posted by MNBoxster
Hi,
bmussatti nailed it since you describe the liquid as cool and watery. But, realize too that this isn't the only possible liquid which could drip on your clutch foot. The Clutch Master Cylinder lives inside the cockpit attached to the firewall behind the clutch pedal shaft and if it's pushrod seal failed, you can also get Brake Fluid dripping on your foot. Not in this case, but it's the only other liquid living anywhere near this area...
Happy Motoring!... Jim'99
Wow, the clutch master cylinder's inside the car? I've never seen that before. Seems like a seal failure there could end up as a pretty big surprise for the driver!
