Old 02-14-2017, 06:03 PM   #10
Gelbster
Originally Posted by Anker View Post
You say you have a light dimming issue. If that's the case you either have a bad battery or an alternator or voltage regulator issue. Have you checked the voltage off the battery terminals when shut off and when idling/running. The first needs to be around 12.5V and the second in excess of 14V.
If power is low all kinds of weird symptoms will arise.
The infamous (Search) "Y connector" corrosion ?
