Old 02-08-2017, 01:08 PM   #19
WorkInProgressK
Originally Posted by Camibox View Post
Update: So I replaced the CPS. I didn't test the new one before I replaced it but tested the old and had no continuity between any of the pins (all read OL). Went to start the car and cranked but didn't try to catch. Saw the tach rise slightly but realized I never heard the fuel pump. Pulled the relay and put in a switch to test. Fuel pump activated. tried the car and it fired right up. 4 times and fired up every time. Wife says "Huh, bad relay". One of the first thing I did was replace the relay but it couldn't hurt, right. Replaced the relay and 3-4 more tries, no issue. We'll see how it goes when we try again tomorrow. BTW, I did test the relay I removed and it activated when I put voltage to the coil.
Called it. glad it was just that. Then again having a having a bad CPS may lengthen starting but not prevent you do drive. CAS is a must.
Best DIY testing method is starting with the cheapest issues first. If it doesn't help keep working at it.
2001 Boxster S (SOLD)
1991 Nissan Silvia "K"(Forgotten somewhere in Canada)
1989 240sx (Track car)
1987 325IS (Soon to be Spec E30 racecar)
2001 GSXR-600 (Almost warm outside!)
WorkInProgressK is offline   Reply With Quote
