Old 02-07-2017, 10:29 AM   #11
Gelbster
If you plan to remove the sump plate often, it may be worth considering replacing the bolts with s/s studs. It saves wearing the threads in the crankcase halves.It is an inexpensive mod. There are s/s studs with an internal hex socket in the head. I think they are M6 coarse but verify length and thread pitch.If you measure crfully ,you'll find the holes in the c/c halves are much deeper than the bolts would suggest. Longer studs in the c/c halves give more 'purchase' for the threadlocker.Make sure you do not have overlong studs hanging below the sump plate.If a dangling stud got caught .....
I used them when I installed a deep sump Blue Loctitie in the c/c and green 290 or 294 after correct torque on the new (flanged?) nuts.YEMV
