Old 01-27-2017, 06:30 PM   #11
JFP in PA
Originally Posted by jeeper31 View Post
I think basically I need to know did I flush the system enough? Should I flush again or can I just add the coolant mixture?
If you are using Porsche coolant, you should be fine. If it is some other coolant, you should fill and dump the system with clear water three times first.
