			Thanks JFP .That makes perfect sense.The warning about the pump is something I did not know.
 Just trying to improve the overall cooling issues. I have to remove the existing heat exchanger to replace leaking oil seals ,so while I am in there I thought ...... But now you have simplified the task. Thank you.
 The new seals I fitted to the HeatX after the rebuild have failed already ! So I hope the ones from Pelican perform better than those that came in the rebuild kit of seals..
