Old 01-18-2017, 01:09 PM   #1
Gelbster
Heat Exchanger delete+oil cooler added
I am considering deleting the heat exchanger on my S and adding an oil cooler with a small fan.
Bilt Racing Oil Cooler Delete. For installing external oil cooler. Eliminates heat exchanger. M96/M97 only. LN Engineering
TRS Porsche Heat Exchanger Delete Plate – M96 M97 | TuneRS
This is an expensive project when you add in the cost of the oil cooler,fan and fittings.
My question is where is the best location for the small oil cooler+fan ? There are some obvious ugly locations that are fine for Racers but is there a discreet ,appropriate void somewhere to put an oil cooler on a Boxster.
And the 6 speed would benefit from an oil cooler also......
Thanks for any practical suggestions
