Old 01-16-2017, 12:15 PM   #1
Gelbster
Suggest you modify the drain holes slightly. There are also 2 in the frunk. Place some s/s mesh on the holes to eliminate debris. This is not fit and forget. You still have to remove debris.It just does not plug the drain. The official screens are expensive but it is easy to make a mushroom shaped piece of mesh to plug into the hole. An old sieve might be repurposed?
