Old 01-14-2017, 07:44 PM   #10
Pdwight
Pdwight's Avatar
Started the job today
Not too bad a job so far, started on the drivers side first and got two cylinders done but that third with the pipe right in front of it...%##&^$^*^%
After pulling the first one I realized I had no spark plugs to install so I would up going to Oriley's and purchasing some Iridium NGK plugs, they were not the fancy quad electrode but they should suffice.
Got the third and last tube installed on the drivers side done when I quit for the evening, one of my problems I have to clean everything and I spent far more time cleaning everything to like new before reinstalling.....also anyone else have the problem when you have a designated car work day that every person you know calls or comes by to ask what you are doing and can you go look at a car I intend on buying....so my eight hour car day turned into more like three hours.
On the plus side the plugs were the perfect color and inside the tube openings everything was shiny clean.
