Old 01-13-2017, 08:59 AM   #5
Gelbster
Some of the links and photos have 'died' in this old thread.
rbcbearing.com has a good pdf showing the solid rod ends available
Here is a current Speedway Motors link for tube and joints:
for example a 1" o.d. x 18"x 3/4"-16 tube(measure yourself!!) is here:
Speedway IMCA Approved 3/4 Thread Swedged Steel Tube, 18 Inches Long | eBay
Swedged Steel Tube, 3/4 Inch Thread
cheap solid rod end LH:
Standard Steel Heim Joint Rod Ends, 3/4-16 LH Male
You would need RH and the correct bore size for the bolt (7/16" = 0.4375")
http://986forum.com/forums/general-discussions/10817-driving-impressions-lower-stress-bar-3.html
