Originally Posted by 911monty
Unless you go to extraordinary length working under the car you run the risk of getting road debris, sand etc. in your coolant. I would not do this and put back into the engine. Everything is much more expensive than coolant.
Agree! Unless you have a spotless engine, you're going to get dirt and debris in the coolant as it runs out and down the various parts of the engine and into the catch pan.
I would recommend not re-using it.
