My harbor freight jack stands, the 3 ton are perfect for the boxster but too short for my FJ. To put them on the highest settings takes multiple lifts as the jack won't lift hugh enough to go to the top setting and the angle is too extreme for comfort anyway. 6 ton HF jackatands, on the lowest setting will kind of fit under the boxster, I use them as backup stands. You can get the min and max heights from HF.
I sometimes do.oil changes by backing down my sloped driveway onto ramps, therefore leveling the car and giving me room, but usually put the car up on 4 jackstands in the garage.
I'll go down tomorrow and make some measurements, I think you could do it with just the 6 ton
