Base model only came with dash speakers, so I think you will need to run some wires to the doors. You will not need an amp - your deck will power door speakers - and you will notice a huge difference in sound.
But - if you are looking for a good, quality sound, you have a lot of work to do my friend. The plus is - there are a ton of good threads on this forum for you to use. You can spend a little or a lot....depending on the quality of the speakers. Just do some searching and you will have an avalanche of info.
Good luck!
