Boxster Spec races with 235's on the front 7" wheel with no problems. On the rear, 255 is stock so you can probably go 275 on the 8.5" wheel but I'm not sure about clearance (maybe someone else can address that).
Toyo RR or R888 (R-copmpound) will be the fastest DOT tires.
