Originally Posted by thomschoon
Lasers read the surface temp while probe types you actually push into the rubber and get a core temp of the tire. I have had both but use a core type as it is more accurate but it is a pain as you have to get immediare temps when you pull off the track or the tires heat sink and the data will be inaccurate.
Hi,
Agreed, the probe is more accurate, but the IR Pyromter is perhaps a tad easier. They're both within the degree of accuracy required by a weekend racer though.
If you're
that anal, consider the Tire Pressure/Temperature system offered by Dakota Digital. It ain't cheap ($399), but it will display Tire pressure on all 4 wheels along with the Temp accurate within 0.1°F in real time as it samples every 0.3 sec. Check it out at
http://www.dakotadigital.com/index.cfm/page/ptype=product/product_id=354/category_id=-1/home_id=-1/mode=prod/prd354.htm Hope this helps...
Happy Motoring!... Jim'99
