Old 12-18-2016, 02:13 PM   #13
Gelbster
Originally Posted by Tweedboru View Post
Hi , I found the quickest and easiest method was to undo the metal jubilee type clamp on the rubber CV boot. slide the boot back a little way, then you have direct access to the bolts. they are very tight and may need a rattler to undo. Added bonus check CV for grease.
Brian
It should be an Oetiker clamp or low profile band clamp.
