Old 12-17-2016, 08:29 AM   #8
Gelbster
The final trick is reassembly
1. the Oeticker clamps- see Pelican for diy
2. zero grease in the threaded holes of the joint at the gearbox end and mild thread locker on the new bolts. You will believe the need when you read what happens when these bolts work loose because of sloppy/greasy re-installation.
