Originally Posted by BoomerRoadie
Can the iSimple Tranzit Blu be used with a CR-210?
As for wire harness, I suggest contacting Crutchfield. Those folks are great!
Yes. No problem.
The iSimple device connects easily. You hook up switched power, ground, antenna in and antenna out. That's it. You may need a VW style antenna adapter to go from iSimple into radio but they're easy to find and under $10.
