Old 12-13-2016, 05:20 PM   #3
dghii
Originally Posted by keeters View Post
I currently have the CDR-23 with the door speakers. I am considering installing a CDR-220 due to its ability to add bluetooth and iPhone support. I would like to add an aftermarket amp to improve the sound quality (I have already upgraded the speakers). How difficult is this job? Can I order a wire harness to connect to the new amp somewhere. Will the speaker wire from the current MOST amp work with an aftermarket amp?
Thanks in advance.
Brad
The CDR-220 is not BT compatible in and of itself. It is capable of adding an AUX input that could be used for a variety of devices.
If all you want to do is add BT, check out the iSimple Tranzit Blu. It connects through the antenna port so you can use it with any radio. It works pretty well with no interference as it is a direct connection.
dghii is online now   Reply With Quote
