Old 12-10-2016, 09:34 AM   #1
Carlisabadman986
Carlisabadman986's Avatar
CEL And Trouble Starting
First off I want to say I have searched and read the other threads specifically with these codes. They all suggest multiple possible issues. Based on the chain of events I am hoping to identify the issue specifically but I wanted the advice of others before I spend time and money trouble shooting.
A week ago I got P0440 Evap system code. I got this code about two years ago, replaced the gas cap and have not had an issue since. Since I know the cap was replaced recently and showed no signs of wear I suspected a larger issue. I cleared the CEL a couple of times this week and every time it came back on with the same code after 20-30 miles.
Friday I went to get gas and after filling up the car did not want to start. After about 5 attempts I finally got it to fire up, drove to work about 20 miles. It drives fine under power and feels normal other than a rough idle.
When I got to work I had three new different codes
P0446
P1130
P1128
My thinking it that since all these codes appeared after filling it up with gas its probably the fuel filler vent/bleeder valve possibly stuck open. Is that logical or do you think that's coincidence?
I replaced the MAF when I bought the car about 5 years ago, I was thinking of cleaning it and seeing if that fixed the issue at least temporarily. I think I was a cheap ass at the time and did not get OEM. Could that be the issue? Also AOS was replaced about two years ago (OEM).
Sorry I know this has been addressed before I was really wondering if anyone thought the codes going off immediately after refueling was a likely symptom of the fuel filler vent bleeder.
It cold and i'm broke so I want to be as purposeful as possible with my time/money
As always any feedback is greatly appreciated.
Thank you for your time and consideration.
01 Base Arctic Silver, Top Speed Muffler and Cat Delete pipes, Ben006 Short shifter
Carlisabadman986 is offline   Reply With Quote
