Originally Posted by BoomerRoadie
Couple things....
I did see that little tiny tab between the blue and green plugs. I tried to pull it back and move the plugs, but it would not budge. I felt like I either wasn't getting the tab pulled back properly or the force was not enough. I thought I'd need some pliers to grip it. I can try that again.
Also, I do have a CD changer and factory amp.
I found this, but I'm still not sure how this would work.
AUX-BKR Auxiliay input Jack for Select Becker Radios with CD Changer :: Auxiliary Input Adapters
Do you want to keep the cd changer connected?
I left it disconnected as I don't use it anymore. All my music is on my phone, and I usually hit the shuffle button. Cd changer is useless to me.
If you go my route, this one will do the job.
https://www.amazon.com/HEADPHONE-SMARTPHONE-iPHONE-ADAPTER-GETWIREDUSA/dp/B01ASJYQ9S/ref=sr_1_3?ie=UTF8&qid=1481390904&sr=8-3&keywords=Becker+blue+plug
Let me know if separating the plugs didn't work for you. I will try and post a video tonight. Doing some suspension work, so the car is on the lift.
