Old 12-07-2016, 08:42 PM   #2
particlewave
There are micro switches in the door latch mechanism (connected to the lock cylinder) that tell the car when you are turning the key. Could be those, the main connector for the door harness (inside door frame) or the immobilizer connectors. Check connectors first for signs of corrosion or bad connection.
