			When you bleed old fluid from a caliper in any location ,the first squirt of old fluid it the bleeder jar is usually the darkest. On that basis it seems prudent to bleed all calipers from all bleed nipples. In the correct sequence. Do not screw up and need to bleed the ABS  ! Instructions are useful if followed.
