Old 11-26-2016, 06:58 PM   #13
steved0x
steved0x's Avatar
Tool is not necessary in my opinion, it just helps get the cable ends on in a position that is intended to give you full range of motion with the shifter handle. It can help prevent you from setting up the cables in such a way that the shifter runs out of room. If you have full range of motion and were able to successfully engage the gears before I don't think the tool would help.
