Old 11-22-2016, 06:55 AM   #4
steved0x
steved0x's Avatar
Every session felt better and smoother than the one before. It won't be hard to improve. I know that I can delay my braking a lot later and accelerate a bit sooner.
Each session feeling better and smoother is a definite improvement!
In my opinion (standard disclaimers):
Later braking doesn't help me so much in terms of gaining extra time from going the higher speed before applying the brakes, but it helps me enter the turn at the right speed. When I brake too soon, I find that I am then going way too slow when I enter the turn. Then when I hit the gas on the way out of the turn, it feels like nothing is happening because I am often down low in the rev range.
This past weekend I was at Sebring and it was the first event on my new Carbotech XP8/10 brake pads. (I've been using EBC Reds for the last few years, worked great and great on the street, but they were worn out and it was time for new pads and rotors anyway so I tried something new). They are a "more powerful", for want of a better word, brake pad, and when I braked at my usual braking points, I was going way too slow by the turn in point. So that took some adjustments...
The other thing I have been working on is trail braking more into the slower/tighter/more car rotation corners. So I have had to move my braking points up for those types of corners as well.
The style of driving I have been working on is to setup my corners so that I can go smoothly to full throttle at the apex and very gradually unwind the wheel as the car "drifts" out to track out. So for a tight corner I am hard on the brakes, make any downshifts required, then trail off the brakes as I turn in to the apex, and then smoothly go to full throttle at the apex and then track out. For faster corners I may be doing a very tiny bit of light trail braking but I try to be on maintenance throttle for the majority of the turn.
I don't know if this is the best approach because this past weekend, using the techniques I am describing, I was totally smoked by a stock 2003 Boxster S that blew my doors off. I mean I was left in the dust... It was both awesome (in that it shows me how much progress I might expect to make) and also kind of embarrassing...
Here is one clip. Disclaimer: I had lifted to let a bunch of cars by that had caught the train I was in, but still... Dang.
https://youtu.be/vxbMpz7qLlU?t=3m41s
Skip to 3:41 to see the other Boxster.
