Old 11-21-2016, 01:32 PM   #15
steved0x
steved0x's Avatar
Originally Posted by stelan View Post
On the 3.2. 99610702601 (later larger drain AOS) I will have the manifold drain thru both larger intake and original larger drain locations for even better oil return as the larger displacement is more demanding. the R&D I have is to do is to make sure system volume is appropriate for fuel trims, etc.
2003/2004 only right? Up through 2002 uses the smaller hole, even on the 3.2? That is what blocks us from using the larger Porsche "Motorsports" dual canister AOS, although I have seen one installation that did it somehow using a hose and a clamp, maybe they drained it to the larger place that you are using?
