Old 11-19-2016, 07:01 PM   #15
steved0x
steved0x's Avatar
If you are between PSS9 and H&R coilovers and you are for track purposes, I would go with PSS9 as I believe it to be much more proven for track use than H&R coilovers.
Not on the list above, Consider adding some solution for more neg camber up front. If you lower some you will get more from.the OEM setup, maybe an additional -.5? I have GT3 LCA and run -2.0 in front which works very well for me.
