Old 07-13-2006, 07:44 AM   #3
MNBoxster
Hi,
The OEM Plugs are either Bosch or Beru, interchangeable. Most likely no difference between the two which are noticeable.
My recommendation is to always go with the OEM Plugs on a Stock engine. This is because a lot of thought went into selecting them in the first place with regard to Heat Range and especially Indexing, that is, which orientation the electrode has to the Flame Front. Using aftermarket ones may fail to maintain this proper Index leading to poorer combustion, greater emissions (or your emissions gear working harder - shorter lifespan) and possibly even a drop in performance and MPG.
Also, your Plugs play a key role in extracting Heat from the Combustion Chamber/Cylinder by carrying it to the water-cooled Head to take away. Different Plugs may less efficient in accomplishing this leading to lots of premature wear issues because of the use of different alloys or design.
Stay away from Platinum Plugs - generally Snake Oil. Lots of Marketing and promises, but few verifiable results. Also, there have been documented reports of the tips breaking off in Boxster engines and causing Piston/Cylinder Head, and Liner damage...
Happy Motoring!... Jim'99
