Several times, not too hard especially if you remove the heater duct that is in the way.
I've had good luck with used ones purchased from other members on this board.
Before doing that, check for the lack of resistance and for continuity on all 6 wires from the pedal sensor connector to the corresponding sockets on DME plug 4. I can provide the pin outs if you need them.
1987 924S. 2002 996TT. PST-2
