Just a related thought:
A 55w headlight draws about 4.5 amps each so without a relay, upgrading to a higher watt headlight bulb as some folks do will also shorten the life of the light switch (as well as burning the plastic lens).
You will need to put in a 10amp+ relay for the headlights that will now trigger from the light switch AND the courtesy light signal wire?
Wondering if the current will flow the wrong way and damage something if the signals are not isolated from each other?
Perhaps a couple diodes will prevent that possibility?
"It broke because it wants to be Upgraded  "
