There may be bigger issues? Try this-
If the friction plate that normally lasts 100K miles (See JFP above for specifics) wears down (to the rivets??) in a few months , there must be a tremendous amount of heat generated from destroying that much material ? My concern is the heat generated in this process. That heat is transmitted to the DMF (is it wobbling ??) and then to the crankshaft.The first vulnerable bearing is #6. That is usually the first to go in normal use ,so in this situation #6 bearing may be very vulnerable and already close to failure.
Suggest some careful DMF and pressure plate detective work required. A defect in the DMF or pressure plate will chew through even the best friction plate and possibly destroy #6 bearing. Best to avoid that ?
Did you use new bolts for the flywheel ? They are another well documented vulnerability.There is an update to the torque spec for the 8 DMF to crankshaft strectch-bolts - 19 ft lbs +120 degrees (not 90! ). If some fool reused the old bolts or substituted generic bolts, that be an issue.
